dark magenta
I want to have a plot and its annotation to use the same color. In PlotXY, I used VAL_DK_MAGENTA, which according to the CVI help is:
VAL_DK_MAGENTARed = 255, Green = 0, Blue = 128
If I use the GUI editor to set the glyph color using the 'More' button with its color popup, this setting returns a quite different color, much brighter...?
It appears tome that VAL_DK_MAGENTA is much closer to 128/0/128...
Wolfgang
(3,810 Views)
Accepted by Wolfgang
Effectively VAL_DK_MAGENTA is defined in userint.h as
#define VAL_DK_MAGENTA                  0x800080L
that is, 128/0/128. Online documentation need to be corrected on this item.
(3,801 Views)
Thank you both for pointing this out. We'll fix the documentation.
Luis
(3,788 Views)
This color is usually called red-purple.
I have those additional colors in some of my projects:
// Some additional (bright) colors
#define VAL_ORANGE 0xFF8000
#define VAL_REDPURPLE 0xFF0080
#define VAL_LTBLUE 0x0080FF
#define VAL_LTGREEN 0x00FF80
#define VAL_PURPLE 0x8000FF
#define VAL_YELLOWGREEN 0x80FF00
Guillaume Dargaud
http://www.gdargaud.net/Hack/GenPalette.html
(3,734 Views)
