decimal to hexadecimal
How can i convert an integer to hexadecimal string in CVI ?
CVI 2017
thanks
(4,471 Views)
Using "%x" format code in sprintf. This is not CVI, it's pure C
(4,454 Views)
j'ai  utilisé  Fmt (hex, "%x<%i",dec) mais ça ne marche pas
(4,439 Views)
Accepted by chayma
Since in this case Fmt expects an integer in output, the correct format should be
Fmt (&hex, "%x<%i", dec);
But this is really useless: there will be no difference in memory between dec and hex! As you surely know, hexadecimal, decimal, octal, binary... are only representations of the very same thing.
You correctly stated in your original question that you wanted a "hexadecimal string", so the correct call should be
char	string[16];
Fmt (string, "%s<0x%x", dec);
(4,434 Views)
Merci pour la réponse
Ça marche bien
Est-ce vous pouvez m'indiquer l'instruction qui convertir de hexadécimal au décimal
Et merci d'avance
(4,427 Views)
Accepted by chayma
That is, extract the number from an hexadecimal string?
sscanf (string, "%x", &dec);
(4,423 Views)
