LabWindows/CVI
deploy labwindows code, what version is required?
QuerulousJohn ha scritto:
However, there is a deficiency in LW as far as a remote screen or panel. LV has the remote screen/panel capability built-in and NI should provide it for LW as well. I was able to make a remote terminal for my LW code, but it required quite a bit of code to communicate from the remote sceen to my main code and consequently was slow.
That's really a good hint! You should post it in CVI Idea Exchange and I will kudo it immediately! Smiley Wink
It is to be said that LV is NI flagship and is always one step ahead of other products. There can be some ways to remote a CVI panel but nothing built-in: I suppose lots of CVI users would benefit for a native utility like that.
Message 11 of 12
(944 Views)
An idea already exists for this on the Idea Exchange with several Kudoes. You should go ahead and add your kudoes as well. I would also suggest posting any comments you have to better define what sort of behavior you would expect from this feature.
Control Labwindows/CVI panel from web browser
Message 12 of 12
(925 Views)
