difference between GetCtrlBitmap and GetCtrlDisplayBitmap
What is the difference between the functions
GetCtrlBitmap() and GetCtrlDisplayBitmap()?
If it matters, this would be using CVI 8.5.
Many thanks.
(4,066 Views)
With GetCtrlDisplayBitmap you can obtain a screenshot image of any control and store it in a bitmap object.
On the other hand, with GetCtrlBitmap you can retrieve an image that is stored inside particular controls like picture controls, picture rings and so on.
(4,053 Views)
Thanks for your reply, Roberto, but I still don't understand.
What is the difference between a screenshot image of a control and
an image stored inside a control?
(4,030 Views)
Accepted by lomed
A picture control can have an image inside it. A numeric or graph control cannot.
With GetCtrlBitmap you can retrieve the image which is loaded inside a picture control and only this one (without control frame, up-down arrows and other details); with GetCtrlDisplayBitmap you can obtain a copy of the complete control even if the control does not have a bitmap in it (e.g. a numeric complete with up-down arrows, radix sign and so on; a graph or stripchart, for which you copy also scale aspect and so on).
(4,023 Views)
