disallowing panel resize below minimum?
Is there a way to forbid active resizing of a panel below minimums?  I've read this post and looked up example projects, but they mostly deal with the EVENT_PANEL_SIZE event (after the resize is done).
I'd like to utilize the EVENT_PANEL_SIZING event which is while the resizing is happening.  The idea is this:
As you click and drag the size of a panel, I would like the panel to stop resizing with your mouse cursor once the minimum height and width dimensions are reached.  This seams like it should be easy.  But I can't quite crack it.
(5,204 Views)
Yes, there's a trick to EVENT_PANEL_SIZING to constrain sizes (I think it's in the list of examples, otherwise search for it).
But personally I find it easier to use EVENT_PANEL_SIZE and GetPanelAttribute(...ATTR_WIDTH) and "if (Width<Limit) Width=Limit" before doing the disposition of my controls. This way you avoid errors (negative size or position controls) while still allowing the user to give the panel a tiny size to get it 'out of the way'. There's no real drawback to this. I think.
(5,201 Views)
Yeah, I have that method working now.  It's funcational, but I don't love it.  The reason is that I feel it gives a "jumpy" effect to the user.  When they attempt a size that is below the minimums, then the callback will force it back to the minimums, which is kind of jolting to my eye.
(5,192 Views)
Accepted by ElectroLund
Eureka!  Good suggestion on the search.  The CVI example projects app didn't find much for this, so I did a search in MS Explorer for "EVENT_PANEL_SIZING".  There's a really great project in there called 'events.cws'.
There's an option to restrict panel sizing dynamically.  A very nice implementation.
The "magic" you mentioned looks to be usage of GetPanelEventRect & SetPanelEventRect.  Not very intuitive a solution, but magical.
(5,191 Views)
