LabWindows/CVI
displaying ssize_t values on an integer control
in a related question to my earlier post (http://forums.ni.com/ni/board/message?board.id=180&thread.id=46242) it is not obvious to me how to display ssize_t values on a numeric control.
For a numeric control, I have to decide using either int or int64, while the idea of ssize_t was that this switching will occur depending on a macro (32 bit or 64 bit compilation)...
Thanks!
(4,503 Views)
Accepted by Wolfgang
Hi Wolfgang,
The only limitation is that, if you're currently relying on the UI editor to set the data type of the control, you'll need to override it programmatically:
    SetCtrlAttribute (panel, control,  ATTR_DATA_TYPE, VAL_SSIZE_T);
Luis
(4,487 Views)
ah, indeed, programmatically all the attributes are available. Good to know 🙂
Thanks!
(4,483 Views)
deleted
(4,098 Views)
