LabWindows/CVI
distribuition can't change Installation dir
I am using CVI 9.0.0.
I need to change the Installation directory for my application.
I read your faq posted in http://digital.ni.com/public.nsf/allkb/C5D3DABE71DFDD9986257545005A9959
but in "All installation locations" i can't find the "directory" voice. I can choose only some directories, but I can't create a own directory.
Daniele
(3,329 Views)
Accepted by d.ghisla
The "All Installation Locations" list contains pretty much anything you might need, unless you want to hard-code a location like E:\MyApp\.  However that would not be a good choice for an installation package, as you can't be sure a target machine even has a drive "E:".
What sort of location are you trying to specify?
I'm guessing you probably want  to select "[Windows Volume]", which will resolve to "C:\"  99% of the time.
--Ian
P.S. You might also want to use GetProjectDir() in your app to ensure you handle all scenarios for different installation locations.
(3,323 Views)
