03-16-2008 12:20 AM
03-17-2008 05:50 PM
03-18-2008 03:20 AM
03-18-2008 10:12 AM
While I know it does not help you achive your objective, I'm quite sure I read somewhere that putting the uninstall item on the Start Menu and not in the Add/Remove Programs panel is contrary to some Windows standards or certification requirements. If I can find the reference, I'll post back.
--Ian
03-18-2008 10:40 AM
See section F1.1 here. It is just a recommendation that we should expect in future versions (Vista?).
As for your needs, I'm sure you have your reasons. I can only suggest researching the command line syntax for msiexec.exe; hopefully someone else can chime in here ...
Good luck.
