LabWindows/CVI
distribution kit with UIR
i have an app. that has some UIR in directory called MY_PROGRAM\UIRS
when i create distribution kit its copy all the UIR to MY_PROGRAM directory and not to MY_PROGRAM\UIRS and because of that the program didnt find its UIR.
what i could do ?
(2,956 Views)
You didn't say what version of CVI you are using. Assuming you are using CVI 6.0, this is what you do. 1) Take you UIR files out of the main file group in the distribution kit using Edit Group...
2) Then create a new file group that has just your UIR files in it.
3) Then select that new group and check "Relative Path" and put in UIRs as the relative path under the application directory.
Best Regards,
Chris Matthews
(2,956 Views)
