LabWindows/CVI
"Problem with distribution kit on MS 6.0"
I'm trying to create distribution kit in LV/CVI 6.0. I've got information that it has been created successfully. Following files are generated:
'Aida II' (size =0b), DistFile.cab (over 3MB),instmsi.exe, instmsiw.exe, setup.exe and the last one: setup.ini with contents:
[Installer]
Title="Aida II: Gui"
Package="Aida II: Gui.msi"
Version=1.10
Msi9x=instmsi.exe
MsiNT=instmsiw.exe
Silent=TRUE
Unfortunately no *.msi file is created so I'm not able to install my applikation on Win2K. What should I do?
(3,023 Views)
I believe the ":" is messing this up. Try naming your program without the : and see if that fixes the problem.
Best Regards,
Chris Matthews
(3,023 Views)
I've found solution. In 'Target Settings' dialog 'Application Title' was different from project name.
(3,023 Views)
