LabWindows/CVI
dynamic memory problems using tab panels
When I use the EasyTab_ConvertFromCanvas() , it seems that I have memory leaks ( verified with the function CVIDynamicMemoryInfo() )...
The Message "Dynamic memory corrupt" appears sometimes... and the system become unstable...
The problem stills when i use DiscardControl and DiscardPanel when i quit the panels with tabs...
Has somebody have the same problem and resolved it ?
(3,531 Views)
Hello clem006
We effectively have seen this kind of problem on certain cirumstances.
For example:
CVIDynamicMemoryInfo() displays a memory leak occuring if EasyTab_ConvertFromCanvas() and InstallCtrlCallback() are used together.
Are you programming the same way.
Could you please provide us a tiny code wich can reproduce the bug.
Regards
Salissou ISSA
NI France
(3,531 Views)
Thanks for your help...
Yes i used EasyTab_ConvertFromCanvas() and DuplicateCtrl...
I think i have found the solution :
all the created controls ( with DuplicateCtrl() ) must be discarded before exiting the panel.
But EasyTab_ConvertFromCanvas() seemed to be bugged because if you put CVIDynamicMemoryInfo() at the end of ni example project for tabs( simpledemo.prj and simpledemo2.prj), there is a memory leak...
Regards
Clement PRESSON
(3,531 Views)
