LabWindows/CVI
mouse listbox scrollbar problem
Hy everyone.
Scrolling listbox problem.
I have a listbox with about 100 elements. I use the vertical scroll bar.
Keyboard up arrow, down arrow, page up and page down works fine.
Whell on the mouse works fine.
If I use (left click on scroll bar up/down arrow) mouse to scroll up/down one position works fine.
Drag the handle of scroll bar works fine.
But paging with the mouse as it is now seems to have a problem with counting.
If you page down, then the item from the bottom will move to the top of the list.
Therefore, it is still visible. If you page up, then the item from the top will
not move to the bottom. It moves to the second invisible position.
If page up and page down would work as they should, then they w
ill show the next
items without showing a single one again and without skipping a single item.
If you are on top of the list, then every page down shall show the next items
without skipping some. The same has to be for paging up from the bottom of the list.
i.e. the items are the numbers 0,1,2,3,....99
If the size of listbox has 11 places and the actual windows displays
20,21,22,...,30 after the mouse page up the windows will display
8,9,10,.......,18 not 10,11,...,20 as Keyboard page up.
Always skip 2 position.
I'm using LabWindows CVI 6.0.
Questions:
- Is this problem solved by LabWindows CVI 7.0 or does exist some LabWindows CVI 6.0
libray patch or like a new LabWindows CVI runtime?
- without exclude scrollbar features can I intercept some event and make a
sw patch into the CVI callback linked to the listbox?
In order to prove this bug and try some solutions I give You a simple project with 2 listbox
(classic and labCVI).
Thank in advance.
(3,594 Views)
hello,
so, i can reproduce the error in CVI 7.0 and the issue is reported ro R&D.
the only way i see, if you would like to build a own software workaround, is to catch the left-click event and set the active item in the list box manually;
but for this you must read the mouse coordinates to find out, if it is scrolling and in which direction.
regards,
Robert H.
(3,594 Views)
