LabWindows/CVI
embed images into project
I've read this thread, and it's close to what I'm after.  I want to switch the image of an image control, but no rely on a path for the image source.  I'd like to select it from the compiled binary.  Possible?
I suppose a solution would be to just have individual controls with the images already loaded.  And then show/hidew the controls?  That seams clunky to me.
(1,819 Views)
Accepted by ElectroLund
If you know the images to use at design time you could use a picture ring control set as an indicator and display the appropriate image depending on program state.
(1,788 Views)
Well, how about that?!  All these years, and I've never known about that control.  That's perfect for me.  Thanks!
(1,777 Views)
