LabWindows/CVI
error -5093 "The analysis library was not found" in 64 bit project. But the analysis library is found in 32 bit project
I'm using the Labwindows/CVI  2010 Full Development system, in a Windows 7 professional 64 bits computer. So, The analysis library is installed (see in the attached file), and the Option Analysis from the Customize library menu is selected.
I'm using several function from analysis library  (WhiteNoise, MaxMin1D, LinFit, etc). The projects in 32 bits work very well. In 64 bits project  there is not linkage error, the exe is created, but there are errors like that:
Function WhiteNoise: (return value == -5093 [0xffffffffffffec1b]). The analysis library DLL was not found or could not be loaded.
the same for the other analysis library functions.
how to do to use the analysis library in 64 bit projects, it's the analysis library 64 bit compatible?
thanks in advance
(5,286 Views)
Accepted by DanSatB
Hi DansatB,
thanks you for posting on this forum !!Smiley Very Happy
Yes, the advanced analysis librairy is 64 bits compatible. i can do the test on my computer on CVI 2013.
i think it will be great to correctly uninstall your CVI version ans all install again.
Regards
(5,252 Views)
I solved the problem:
I uninstalled labwindows cvi,
i restarted my computer
i used ccleaner to clean the registry.
I installed Labwindows/ CVI.
!Now, All it's Ok!,  the analysis library is found in 32 and 64 projects.
(5,246 Views)
Thank's  for your response.
I solved the problem, as you said.
(5,244 Views)
