12-09-2013 06:48 AM
I'm using the Labwindows/CVI 2010 Full Development system, in a Windows 7 professional 64 bits computer. So, The analysis library is installed (see in the attached file), and the Option Analysis from the Customize library menu is selected.
I'm using several function from analysis library (WhiteNoise, MaxMin1D, LinFit, etc). The projects in 32 bits work very well. In 64 bits project there is not linkage error, the exe is created, but there are errors like that:
Function WhiteNoise: (return value == -5093 [0xffffffffffffec1b]). The analysis library DLL was not found or could not be loaded.
the same for the other analysis library functions.
how to do to use the analysis library in 64 bit projects, it's the analysis library 64 bit compatible?
thanks in advance
Solved! Go to Solution.
12-10-2013 07:09 AM
Hi DansatB,
thanks you for posting on this forum !!![]()
Yes, the advanced analysis librairy is 64 bits compatible. i can do the test on my computer on CVI 2013.
i think it will be great to correctly uninstall your CVI version ans all install again.
Regards
Aurélien Corbin
National Instruments France
12-10-2013 07:16 AM
I solved the problem:
I uninstalled labwindows cvi,
i restarted my computer
i used ccleaner to clean the registry.
I installed Labwindows/ CVI.
!Now, All it's Ok!, the analysis library is found in 32 and 64 projects.
12-10-2013 07:19 AM
Thank's for your response.
I solved the problem, as you said.
