LabWindows/CVI
error in asynctmr.c?
Hallo
I have made some experiments with the async timer functions in CVI 5.5.
I use the NI App. Wizard to convert the cvi Projekt to Visual C++. Sorry, but I like the editor and debugger more than the CVI tools.
The compiler gave me an error in asynctmc.c at line 464:
// This routine removes the Async Timer from the list given the pointer to it
// This routine asssume you are in the critical section
static MMRESULT RemoveAsyncTimer(tAsyncTimerRec *asyncTimerPtr)
MMRESULT mmResult;
double currentTime;
double deltaTime;
// Disable the timer
asyncTime
rPtr->status == ASYNC_TIMER_DISABLED;
I think this is realy an error, because the status flag does not change its value.
By the way: is the sa same c code used, when I use the toolbox.fp?
Stephan Gerhards
DATALOG Systeme zur Meßwerterfassung GmbH & Co. KG
Trompeterallee 110,
D-41189 Mönchengladbach
Tel.: +(49) 21 66/ 95 20 59
Fax: +(49) 21 66/ 95 20 20
e-mail: stephan.gerhards@ni.com
Message 1 of 1
(3,255 Views)
