ethernet in cvi
i am using labwindows/cvi 2018.3 . I am using control panel graphical user interface.
how to send the data through the Ethernet .
(2,306 Views)
Whom are you sending your data to? Normally is the target that specifies how to send data.
BTW, what do you mean by "control panel graphical user interface"?
(2,273 Views)
i need to send data from cvi to microcontroller and microcontroller to cvi
Any guiding materials is available
(2,263 Views)
Does your microcontroller implement some form of TPI/IP stack? Can it operate as a server?
I suppose there actually is a ethernet port so it is possible that the micro comes with a ethernet library.
(2,253 Views)
