06-08-2020 11:56 PM
i am using labwindows/cvi 2018.3 . I am using control panel graphical user interface.
how to send the data through the Ethernet .
06-09-2020 04:11 AM - edited 06-09-2020 04:13 AM
Whom are you sending your data to? Normally is the target that specifies how to send data.
BTW, what do you mean by "control panel graphical user interface"?
06-09-2020 04:45 AM
i need to send data from cvi to microcontroller and microcontroller to cvi
Any guiding materials is available
06-09-2020 06:24 AM
Does your microcontroller implement some form of TPI/IP stack? Can it operate as a server?
I suppose there actually is a ethernet port so it is possible that the micro comes with a ethernet library.
