LabWindows/CVI
event log
Okay basically i have to create a event log , is there any projects out there that i can reference.
Also what are some good questions i can ask pertaining to this event log .
to gather all of the requirements successfully.
Basically one of my requirements is to define critical bit errors, can someone also direct to a site about the different Built in test like IBIT, MIT, what does I, M mean and so on
any guidance to a starting point
(3,482 Views)
ok more notes, i have to open a text file basically, and then store the results into a database. to compare whats going on. so the event log i know how to do. its the database i got to get familiar with , is there any projects i can reference regarding databases
(3,453 Views)
Hi darnell,
I would recommend using the SQL toolkit if you need database communication. You can find more information in the toolkit reference manual, located here:
LabWindows/CVI SQL Toolkit Reference Manual
Al B.
Staff Software Engineer - TestStand
CTA/CLD
(3,432 Views)
