LabWindows/CVI
Distributions
I am building a distribution that requires DAQmx.  When building I get an error "Cannot find distribuition NI DIAdem 11.0".
Where would this file be found?
(3,884 Views)
Accepted by topic author Paul_Knight_Lockheed_Mart
You will need to provide the NI DIAdem 11.0 disk. Some software was installed to the system from this distribution, and at least one component from it (i.e. shared component also required by DAQmx or NI installer framework) needs to be copied from that disk.
Mert A.
(3,877 Views)
(3,873 Views)
