LabWindows/CVI
Distributions
I am building a distribution that requires DAQmx.  When building I get an error "Cannot find distribuition NI DIAdem 11.0".
Where would this file be found?
(3,911 Views)
You will need to provide the NI DIAdem 11.0 disk. Some software was installed to the system from this distribution, and at least one component from it (i.e. shared component also required by DAQmx or NI installer framework) needs to be copied from that disk.
Mert A.
(3,904 Views)
(3,900 Views)
