examples of tcp/ip
how do i use TCP/IP protocol in LabWindows/cvi without using its callback function?
(3,730 Views)
Hi Vallabh,
normally its done with datasocket function, but there you have some Callbacks. So I am not really sure what you mean. you also can have a look to that thread.
There is an example of using the datasocket function to download a web page.
so long
Michael
(3,723 Views)
Well you could just call the Server/ClientTCPRead() and Server/ClientTCPWrite() functions directly - they have a timeout facility in the event of a connection problem, but it seems a bit inefficient. Is there a particular reason you want to avoid the CVI callback mechanism? It really is very easy to use and quite efficient.
JR
(3,718 Views)
