LabWindows/CVI
extra Panel in Panels and Controls in panel generated .h file
I have one panel in my project, it is called LO_LVL_PNL.
The generated header file seems to think there is more. Here is the "Panels and Controls" section on the generated header file:
/* Panels and Controls: */ #define DITHER 1 #define DITHER_CLOSE 2 /* callback function: DITHER_CLOSE_CB */ #define DITHER_Dither_Settings 3 /* callback function: DITHER_CONTROL */ #define LO_LVL_PNL 2 #define LO_LVL_PNL_SENDBUTTON_2 2 /* callback function: DIDsBUTTONcb */ #define LO_LVL_PNL_SENDBUTTON_3 3 /* callback function: EraseBUTTONcb */ #define LO_LVL_PNL_SENDBUTTON_4 4 /* callback function: SENDBUTTON_noe_cb */ #define LO_LVL_PNL_SENDBUTTON 5 /* callback function: SENDBUTTONcb */ #define LO_LVL_PNL_RESET_CAN 6 /* callback function: RESET_CAN_CB */ #define LO_LVL_PNL_UUTRESPONSE 7 /* callback function: UUT_RESPONSE */ #define LO_LVL_PNL_CLEARBUTTON 8 /* callback function: CLEARBUTTONcb */ #define LO_LVL_PNL_EXIT_BUTTON 9 /* callback function: cb_quit */ #define LO_LVL_PNL_Comm_Set_TEXTBOX 10 #define LO_LVL_PNL_COMMANDBUTTON 11 /* callback function: CheckState */ #define LO_LVL_PNL_COMMANDBUTTON_2 12 /* callback function: Select_Files_DID */ #define LO_LVL_PNL_BINARYSWITCH 13 /* callback function: SetProgram */
in my UIR I can find the LO_LVL_PNL components, but not the DITHER pieces.
So, I renamed my generated header file, so it would regenerate it without these extra items, but they get included when I recreate it.
In the UIR file, if I double click he panel it opens and shows the panel is indeed called LO_LVL_PNL.
This started because I am trying to read the value of a switch on the panel, and in the call I get a run time error that follows:
            GetCtrlAttribute(LO_LVL_PNL, LO_LVL_PNL_BINARYSWITCH, ATTR_ON_VALUE, &on_off);
NON-FATAL RUN-TIME ERROR:   "gui_handler.c", line 135, col 13, thread id 0x0000179C:   Library function error (return value == -42 [0xffffffd6]). The handle is not a panel handle
I don't know if this is two separate issues, or the DITHER things cause the error; but I need help to fix both.
(3,695 Views)
The first parameter to GetCtrlAttribute() should be the panel handle, not the panel ID. The handle is returned from your LoadPanel() call.
Did you ever have a panel called DITHER? Copied from a previous project, perhaps? Maybe the UIR editor has hidden it or placed it off-screen. Try using the Find Panel editor option to see.
JR
(3,692 Views)
JR,
Right on both counts.
Got rid of the extra stuff and got the handle, problem is a naming issue, the handle is LO_LVL_PANEL, the constant is LO_LVL_PNL; too close for my comfort. I'm going to change this before I make the same mistake.
(3,686 Views)
Hi Ken,
Not directly related to your question but I could not help responding when I saw the UIR names.
It is always nice to have a naming convention when building your GUI.
Always capitalize the panel and control constants.
Personally, I pick short (single word, without underscores etc) names like "MAINPNL" for panel names because they appear as prefix to every control on that panel.
I also add a 3-4 letter prefix to every control according to their type. i.e: BTN_QUIT
This way I can recognize every control from its name and still their names stay short.
Better than writing COMMANDBUTTON at the end of every control.
S. Eren BALCI
IMESTEK
(3,670 Views)
ebalci,
I'm working with inherited code; mostly. Trying to clean it up a little, but I don't have too much time to tinker with it.
(3,663 Views)
