LabWindows/CVI
first derivatives
Is there a equalivent LabWindows/CVI function for the LabView NI_AALPro.lvlib:Derivative x(t).vi?  I notice that it ends up at a Call Library Function "Derivatives85" in the lvanlys.dll.
I need to find the transition point where the slope goes vertical in the attach graph.
(4,986 Views)
Try the advanced analysis library PeakDetector function.  It will also find second derivatives for you.
Menchar
(4,983 Views)
Thanks, that solved the issue.
(4,939 Views)
Hi Paul,
The "solution" to your question is what menchar provided, not your "thank you" message.
For the sake of healthy forum statistics mark the "answer" that solves your problem, not your own messages.
Take care, 😉
S. Eren BALCI
IMESTEK
(4,912 Views)
S. -
Thanks for pointing that out Smiley Very Happy
I had noticed what had happened, it was kind of funny actually.
Menchar
(4,897 Views)
