LabWindows/CVI
fwrite error : trying to write 26 bytes to file and having issues
i am trying to write 26 Hex Bytes data to file using fwrite and i am having unknown issues due to which 27 bytes get written
/////////////////////////////////// Code ///////////////////////////////////////////////////////////////////
    FILE *READ;
    READ = fopen ("DataReceived.dat" , "w"); // opening file for writing
    unsigned char data2send[26] = { 0x00 , 0x00 , 0x00, 0x00, 0x00 , 0x00 , 0x00 , 0x00 , 0x00 , 0x00,
 0x00 , 0x00, 0x00, 0x00 , 0x00 , 0x00 , 0x00 , 0x00 , 0x00 , 0x00, 0x00 , 0x00 , 0x00 , 0x00, 0x00 , 0x00 };
data2send[0]=0xEB; // assigning Data
data2send[1]=0x90; // assigning data
data2send[10]=0x08;// assigning Data
crcsent = calCRC16(data2send, 24); // calculating CRC of 24 bytes and adding (16 bit) crc to last two bytes of data
data2send[24]=(crcsent>>8) & 0xFF; // crc added to second last byte
data2send[25]= (crcsent & 0xFF);   // crc added to last byte
if(ComWrt( coms , data2send , 26)==26)  // sending data to com port
    fwrite (data2send, 1, 26 , READ); // ===> writing data to file where there is problem
Output (WRITTEN to the file )should be ::
0xEB  0x90  0x00  0x00  0x00  0x00  0x00  0x00  0x00  0x00  0x08   0x00  0x00  0x00   0x00  0x00   0x00   0x00   0x00   0x00  0x00   0x00   0x00   0x00  0x0A   0xA1
Output which i get on the file ( which is incorrect ) and it should not be done because i have specified 26 bytes to write
0xEB  0x90  0x00  0x00  0x00  0x00  0x00  0x00  0x00  0x00  0x08   0x00  0x00  0x00   0x00  0x00   0x00   0x00   0x00   0x00  0x00   0x00   0x00   0x00  0x0D   0x0A   0xA1
how 0x0D is added to my data although i am only adding data to byte 0,1,10,24,25
when i am writing 26 bytes then how 27 bytes get written on to the file ??
thanks in advance
ahsan
(6,008 Views)
Accepted by smartprogrammer
I can only guess that the problem may arise from opening the file in text mode and writing a newline character to it (0x0A): the system may automatically add a carriage return (0x0D) to maintain the CRLF standard. Try opening the file in binary mode instead (fopen with "wb" specification).
(5,999 Views)
thanks alot my dear respected friend you are always there to help ,,  i admire your helping nature and knowledge. thanks alot
(5,983 Views)
