‎09-11-2003 03:02 PM
‎09-12-2003
05:53 PM
- last edited on
‎03-25-2026
12:24 PM
by
Content Cleaner
Unfortunately, the DIO lines on the PCI-6052E are only static. They cannot perform hardware-timed I/O. For some, a software-timed loop is sufficient, but I see that this is not possible in your case.
There are other Multifunction DAQ boards that do support strobed DIO. The PCI-6025E is a 12-bit board that contains an 8255 chip that can perform handshaking I/O. On the other hand, the NI PCI-6120 is a simultaneous sampling 16-bit board that supports strobed I/O on it's digital lines.
I hope this helps!
Russell
Applications Engineer
‎09-13-2003 07:59 AM
‎09-16-2003 12:51 PM
