I'm using labwindows with a pci6052E card that has only 8 di/o lines which I'm already using. I need a 9th TTL line for the electronics I'm controlling. What is the easiest way to do this using the other outputs available ? i.e. analogue out or counter/timer lines. It doesn't need to be fast at all, just able to switch between 0v and 5 v under the control of a button on the user interface.
I'm assuming I could use the analogue out line but that seems a bit heavy handed. Is there a way to programme a counter/timer line so you can just switch it high or low easily? I've looked through all the nidaqmx functions and can't find anything that looks suitable.
I would be grateful for any ideas.
thanks
