how do I get dataacq.h?
I am trying to work on some LabWindows/CVI code given to me from a prior version of an application I am upgrading. When I try to build, it seems I am missing the "dataacq.h" header in my LW/CVI installation. I have searched for this file and it is nowhere to be found in my installation directory. Is there another code module or instrument driver I need to install? Does anyone know how I get that particular header file? Thanks in advance,
Andy
Message 1 of 19
(11,284 Views)
forgot to mention, I am using version 7.0, whereas the old application was built w/ either version 5.5 or 6.0 of LW/CVI.
Message 2 of 19
(11,280 Views)
The following two links may help you out:
http://groups-beta.google.com/group/natinst.public.labwindows-cvi.general/browse_thread/thread/a224606435abf937/2b41ae1a9f61ba2a?q=%22dataacq.h%22&rnum=1&hl=en#2b41ae1a9f61ba2a
http://groups-beta.google.com/group/natinst.public.labwindows-cvi.general/browse_thread/thread/cfca2e07480f6f38/566cd1f687c916a8?q=%22dataacq.h%22&rnum=4&hl=en#566cd1f687c916a8
Message 3 of 19
(11,285 Views)
thanks, Dave. In reading those links, it looks like I need to load the NI DAQ driver. I guess this is a separate product from LW/CVI & I need to look into either downloading it or buying it, whichever. I assume there is some info on NI's site, I am not familiar with this product and will have to research it further. Thanks again,
Andy
Message 4 of 19
(11,269 Views)
Hi AJ-
The NI-DAQ driver is a free download from www.ni.com
All versions of NI-DAQ (including NI-DAQmx 7.4) include the Traditional DAQ API that will install the file you are missing. You will need to make sure that LabWindows/CVI support is installed- this option should be enabled by default, but make sure that the installation directory is the same directory that CVI is installed on your system.
Message Edited by Tom W. on 05-16-2005 12:21 PM
Message Edited by Tom W. on 05-16-2005 12:22 PM
Tom W
Message 5 of 19
(11,261 Views)
Hi AJ-
Tom W
Message 6 of 19
(11,255 Views)
thanks, Tom W. RE: "....but make sure that the installation directory is the same directory that CVI is installed on your system."
Sounds like a good tip, I will watch out for that.
aj
Message 7 of 19
(11,233 Views)
I am using LabWindows/CVI version 8.0.1 and have downloaded NIDAQ version 8.1.0 but I do not have the file "dataacq.h" anywhere.
Do I have the wrong versions/components????
Message 8 of 19
(10,955 Views)
Hi Bendt-
The information I posted previously is incorrect now; the Traditional NI-DAQ (Legacy) driver is not bundled with versions of NI-DAQmx 7.5 and later.  There is a seperate download available.
Hopefully this helps-
Tom W
Message 9 of 19
(10,930 Views)
Thanks, Tom W. that works.
Message 10 of 19
(10,911 Views)
