‎05-13-2005 12:08 PM
‎05-13-2005 12:10 PM
‎05-13-2005 12:48 PM
‎05-16-2005 06:53 AM
‎05-16-2005
12:20 PM
- last edited on
‎07-08-2025
02:17 PM
by
Content Cleaner
Hi AJ-
The NI-DAQ driver is a free download from www.ni.com.
All versions of NI-DAQ (including NI-DAQmx 7.4) include the Traditional DAQ API that will install the file you are missing. You will need to make sure that LabWindows/CVI support is installed- this option should be enabled by default, but make sure that the installation directory is the same directory that CVI is installed on your system.
Message Edited by Tom W. on 05-16-2005 12:21 PM
Message Edited by Tom W. on 05-16-2005 12:22 PM
‎05-16-2005
12:21 PM
- last edited on
‎07-08-2025
02:18 PM
by
Content Cleaner
Hi AJ-
‎05-17-2005 10:34 AM
‎06-14-2006 03:19 AM
I am using LabWindows/CVI version 8.0.1 and have downloaded NIDAQ version 8.1.0 but I do not have the file "dataacq.h" anywhere.
Do I have the wrong versions/components????
‎06-14-2006
09:28 AM
- last edited on
‎07-08-2025
02:18 PM
by
Content Cleaner
Hi Bendt-
The information I posted previously is incorrect now; the Traditional NI-DAQ (Legacy) driver is not bundled with versions of NI-DAQmx 7.5 and later. There is a seperate download available.
Hopefully this helps-
‎06-15-2006 12:36 AM
