how do you generate a pulse train while a counters gate is high?
I am using a NI 6025E/Traditional DAQ/C++  and would like to generate a pulse train on counter 1
while it's gate signal is high. Does anybody have any example code or know which function calls
to use?
Any help would be greatly appreciated.
JD
(2,870 Views)
Hi JD,
A good example that will help get you started is STCgenerateSquareWave.C.  This example is located in C:\Program Files\National Instruments\NI-DAQ\Examples\VisualC\Ctr.
A function that could help you with this application is the GPCTR_Change_Parameter function. Further details about the function can be found in the Traditional DAQ C Function Reference Help.  This is located in Start>>All Programs>>National Instruments>>NI-DAQ.
I hope this information helps you with your application.
Hal L.
(2,857 Views)
