LabWindows/CVI
how do you remove watch window expression?
I have Labwindows 8.5 and it seems I couldn't find anyway to remove the watch expression variables and many of them are no longer valid but still remain there. There is no delete command to delete the variables. The section in GettingStart.pdf used to have a delete command in previous LabWindows now is gone. Is there a way to delete the variables because it's annoying?
(4,316 Views)
Accepted by UKnowWhat
Select the watch expression and hit the Delete key. I agree that it would be clearer if there were a menu item as well.
Mert A.
(4,315 Views)
or a simple instruction in the help file would help too. Like yours.
Thank you.
(4,298 Views)
