LabWindows/CVI
how to control power supply (Agilent E3631A) with CVI
Dear,
I got a tough problem about controlling (via GPIB) Agilent E3631A power supply with cvi 6.0. After I run my app and start to initialize the power supply, but then my app can not continue to initialize the Base station (R&S CMU200).
the relative code is as below:
   // INIT PS, Reset device
  OutputStatus("Initiating PS Simulator...");
  HelloPanelOn("PS Operation","Initiating PS simulator...");
 // CheckPsError(hpe363xa_init ("GPIB::5::%d", VI_TRUE, VI_TRUE, &PS_GPIB_ADDR_handle));
  CheckPsError(Power_Supply_Init (g_vPsGpibAddr, VI_TRUE, VI_TRUE, &g_vPsHandle));
  CheckPsError(Power_Supply_OnOff (g_vPsHandle, g_vVoltage, 3.00, VI_TRUE));
  CheckPsError(Power_Supply_Set ( g_vPsHandle, g_vinstrument, 3.8));
  CheckPsError(Power_Supply_Set_Current (g_vPsHandle, g_vinstrument, 3.00));
  HelloPanelOff();
   // INIT BS, Reset device
   OutputStatus("Initiating BS Simulator...");
   HelloPanelOn("BS Operation","Initiating BS simulator...");
   CheckBsError(BS_Init(g_vBsType,g_vBsGpibAddr, VI_TRUE,VI_TRUE,&g_vBsHandle));
   HelloPanelOff();
Actually, I am not so clear about how to control Power supply . Does anybody can share his/her cvi code, which can control power supply?
Thanks a lot!
crystal
(3,852 Views)
Hi, crystal,
 a few comments and questions concerning your code
It seems that  you did try to use the National Instruments Instrument driver for the E363x series here.
But this doesn't work, because you didn't setup the Resource Name right.
What driver/library are you using here ? Does it really support the E3631A ? The E3631A is different to the other E363x series supplies, because it has 3 voltage outputs. And this driver seems to lack the ability of setting up more than one output , because these is no option to choose the output.
Here a snippet of code were are using build upon a version of the NI Instrument driver. Probably  you want to adapt the error handling to your needs.
    // Initialize PS_P24V
    Fmt(resource_id,"GPIB::%d[w2]::INSTR",addr_PS_P24V);
 status = hpe363xa_init (resource_id, VI_TRUE, VI_TRUE,
       &Instr_Handle_PS_P24V);
    if ( status ) {
     error = status ;
  status = hpe363xa_error_message (Instr_Handle_PS_P24V, error, errMsg);
     goto Error;
    // Specify Output of Power Supply P24V
    status = hpe363xa_reset (Instr_Handle_PS_P24V);
    if ( status ) {
     error = status ;
     goto Error;
 status = hpe363xa_ConfigureVoltageLevel (Instr_Handle_PS_P24V, ps_channel, 24.0);
    if ( status ) {
     error = status ;
     goto Error;
 // status = hpe363xa_outputOn (Instr_Handle_PS_P24V, hpe363xa_OUTPUT_ON);
 status = hpe363xa_ConfigureOutputEnabled (Instr_Handle_PS_P24V, ps_channel,
             VI_TRUE);
    if ( status ) {
     error = status ;
     goto Error;
 status = hpe363xa_Measure (Instr_Handle_PS_P24V, ps_channel,
          HPE363XA_VAL_MEASURE_VOLTAGE,
          &voltage_PS24);
 if ( status ) {
     error = status ;
     goto Error;
          HPE363XA_VAL_MEASURE_CURRENT,
          &current_PS24);
  if ( status ) {
     error = status ;
     goto Error;
(3,837 Views)
Hi
Thanks for your explanation. I will try to change my code regarding your example:-)
crystal
(3,821 Views)
