LabWindows/CVI
how to convert achar array to char string in labwindows/CVI?
I read a txt file, i want to have the char array convert to char string,and place the converting char string into a string indicator.how to carry out?
(4,443 Views)
Why do you want to perform such a conversion? If as an example you are reading with ReadLine, you can simply pass the string buffer to SetCtrlVal and display the text.
static char buffer[256];
static int fileHandle;
ReadLine (fileHandle, buffer, 255);
SetCtrlVal (panelHandle, PANEL_STRING, buffer);
(4,440 Views)
