LabWindows/CVI
how to convert to workspace window in CVI
I use CVI6.0 to open an app, but the window is not the workspace window, please look at it at the attachment.
How to convert it to workspace window. thanks
crystal
(3,411 Views)
Crystal, what are you trying to do exactly? The project window in cvi 6 can hold only files necessary to a project: source, include, UIRs, libraries and instruments; you cannot load any other file in it.
(3,401 Views)
Hi Roberto,
sorry my question is not so clear.
When I use CVI 6.0 to open a CVI project file, the CVI  window doesn't display as the normal workspace window,which can see the project tree window,library tree window,code window.   The CVI display only three column, could you please look at the word file in the attachment?
I put the CVI window in it. Hope you can understand what I mean. thanks
crystal
(3,400 Views)
OK, now it's crearer.
The workspace integrated view is a feature NI introduced with CVI 7: cvi6 has no integrated workspace view into which to have all projects. Instead, it is focused on individual projects, even though you can create a workspace that includes more than one of them.
(3,394 Views)
Thanks Roberto, I think that is the reasonSmiley Happy But now the small tough problem is my old app is compiled with CVi6.0, I use cvi7.0 to update it. However, the successful debug file with cvi7.0 doesn't work .... I am checking it these days! Hope you can help when I meet new problems. thanks
crystal
(3,382 Views)
