Hello Dwivedi,
If you just need to call your CVI application, I would suggest creating and calling the executable in another program. If you need to use ActiveX, you can create an ActiveX controller for CVI itself. Navigate to "Create ActiveX Controller" from the Tools menu, then select NI LabWindows/CVI Server
. This will add a function tree to your CVI environment, that will allows you to use the exposed ActiveX CVI environment functions.
Hope that helps.
Wendy L
LabWindows/CVI Developer Newsletter
