how to increase panel title size in 5.5
Message 1 of 9
(5,821 Views)
Open the .uir, go to Edit, Panel. Click on Title Style and you can change the font.  Make sure Size Title Bar Height to Font is checked.
walttheengineer
Message 2 of 9
(5,796 Views)
this is true only for child panels...
Message 3 of 9
(5,780 Views)
i tried this in edit panel >title style but no effect in the output only i can change title name....please help me
Message 4 of 9
(5,765 Views)
You cannot do this for the main panel using CVI functions - maybe the Windows API provides such a possibility
Message 5 of 9
(5,762 Views)
I wasn't suggesting it be done thru functions calls.  It's a simple use of the existing menu as I described earlier.  I've done this in both 5.5 and 8.1.  It's simple and straightforward.  I don't understand the problem you are having.
Message 6 of 9
(5,690 Views)
Accepted by engine_motor
...because your suggestion works only for child panels, not for regular panels...
Message 7 of 9
(5,683 Views)
I got it now.  I misinterpreted the LoadPanel function explanation.  Child Panel works for me anyway.  Thanks for the insight.
Message 8 of 9
(5,569 Views)
thnku now its working
Message 9 of 9
(5,533 Views)
