LabWindows/CVI
how to increase panel title size in 5.5
Message 1 of 9
(5,889 Views)
Open the .uir, go to Edit, Panel. Click on Title Style and you can change the font.  Make sure Size Title Bar Height to Font is checked.
walttheengineer
Message 2 of 9
(5,864 Views)
this is true only for child panels...
Message 3 of 9
(5,848 Views)
i tried this in edit panel >title style but no effect in the output only i can change title name....please help me
Message 4 of 9
(5,833 Views)
You cannot do this for the main panel using CVI functions - maybe the Windows API provides such a possibility
Message 5 of 9
(5,830 Views)
I wasn't suggesting it be done thru functions calls.  It's a simple use of the existing menu as I described earlier.  I've done this in both 5.5 and 8.1.  It's simple and straightforward.  I don't understand the problem you are having.
Message 6 of 9
(5,758 Views)
Accepted by topic author engine_motor
...because your suggestion works only for child panels, not for regular panels...
Message 7 of 9
(5,751 Views)
I got it now.  I misinterpreted the LoadPanel function explanation.  Child Panel works for me anyway.  Thanks for the insight.
Message 8 of 9
(5,637 Views)
thnku now its working
Message 9 of 9
(5,601 Views)
