LabWindows/CVI
how to read cursors of plots of CWGRAPH control
hi,
This problem is about CWUI_graph AcitveX control.There are 4 plots in
my graph. I want to continuously read the coordinate of the 4 plots at
the same when I move the cursor whose crosshair is" major X &
Minor",Snap Mode "Point on any plot".
I have registered the cursorchange callback:
HRESULT CVICALLBACK finddata(CAObjHandle caServerObjHandle,
void *caCallbackData,
long *cursorIndex,
VARIANT *XPos,
VARIANT *YPos,
VBOOL *bTracking);
But it can only read one plot at a time.
So I use "CWUIControlsLib_CWCursorSetPlot" to change the plot of
cursor ,and t
hen I use"CWUIControlsLib_CWCursorSetXPosition" to set
the poistion of the cursor in the callback function. I thought it
would invoke the callback function again because the cursor had been
changed,in this way I can read the YPos of that plot.But I failed,the
callback function had not been invoked.
who can tell me what is the best way to read cursors of all plots at
the same time. Thanks a lot.
(2,890 Views)
The ActiveX callback function will not be called if you change the cursors yourself, the callback will only be generated when the user makes some chages to it. However you can call the callback functio yoursef; basically after you change the possition of the cursor you call finddata(...) with all the parameters required. If you don't have a parameter available just pass a dummy value.
I belive this will be the fastes way to go through all the plots.
I hope this helps.
Juan Carlos
N.I.
(2,890 Views)
