LabWindows/CVI
how to run a GPIB program in labwindows/cvi 4.0 with win 2000/xp?
I tried to run the exemple of the use of GPIB, but it returns me this error: "DLL init Error:
"Could not find the function or variable ´CalcChildScroll´in the DLL
"user32.dll". I tried to run a GPIB program design by myself and it´s the
same, anytime that I use a GPIB command, this happens, Rigth now I`m using LabWindows/CVI 4.0 under Windows 2000, I also tried
changing the operating system to windows XP and shows the same error.
Please tell me how to solve this.
(2,872 Views)
LabWindows/CVI 4.0 is not compatible with Win 200 or XP. Please check the link below,
LabWindows/CVI and the Platforms It Supports
You can upgrade to LabWindows/CVI 6.0, which is the current version and compatible with Win 200 and XP. Also, please make sure you have the latest GPIB driver installed on your machine.
Mika Fukuchi
Application Engineer
(2,872 Views)
