LabWindows/CVI
why does the ADO create query fail?
I have successfully create an activex controller from ADO. Below I am opeing a database and then trying to build a query. In this case I just want to count the number of records in the database. My DAO_DatabaseCreateQueryDef() command is failing. Can anyone tell me what is wrong with this code?
iRc = DAO_NewDBEngineDBEngine (NULL, 1, LOCALE_NEUTRAL, 0, &CAOHEngine);
iRc = DAO_DBEngineCreateWorkspace (CAOHEngine, NULL, "WORKSP1", "name", "password", CA_VariantInt (DAOConst_dbUseODBC), &DAOOWorkspace);
iRc = CA_CStringToBSTR ("SELECT * FROM main_balance", &bstrConn);
iRc = CA_CStringToBSTR ("", &bstrQuery);
iRc = DAO_WorkspaceOpenDatabase (DAOOWorkspace, NULL, "chicagowebs", CA_DEFAULT_VAL,CA_DEFAULT_VAL, CA_DEFAULT_VAL,
&DAOOdatabase);
iRc= DAO_DatabaseCreateQueryDef (DAOOWorkspace, NULL, CA_VariantBSTR (bstrQuery), CA_VariantBSTR (bstrConn), &DAOQuery);
iRc = DAO_DatabaseOpenRecordset (DAOOdatabase, NULL, "main_balance", CA_DEFAULT_VAL, CA_DEFAULT_VAL,
CA_DEFAULT_VAL, &DAORecordset);
iRc=DAO_GetRecordsetProperty (DAORecordset, NULL,
DAO_RecordsetRecordCount, CAVT_LONG, &iVal);
Message 1 of 1
(3,105 Views)
