LabWindows/CVI
how to sort files in file selection dialog box?
Hello everyone:
i am dealing with the problem with file selection dialog box. for example i have a file selection dialog box, a lot of file items inside it. I would like to programtically set the files sorting like by number as default, like bat_1211, then bat_1210, then bat_1209, bat_1208, etc. So if the file selection dialog box appear, then i can see the file items sorted and showed to me as i hope.
Thank you!!!
(3,295 Views)
Hi schoolworkwork,
I assume you are using the FileSelectPopup dialog. That dialog box doesn't allow much customization as we made it for simplicity purposes. I would take a look at the Customizing the LabWindows/CVI FileSelectPopup Dialog KnowledgeBase to see what alternatives you have that best suite you.
Best Regards,
Jonathan N.
(3,283 Views)
Hi Jonathan N:
You got my question, but it seemed difficult after i took a look at the link. If you can help then tell me.
Thank you very much!!!
schoolworkwork
(3,263 Views)
