LabWindows/CVI
transpose 1 dimensional array
Dear All,
I´m using "Write to spreadsheet file" to write out a one dimensional array acquired from a tektronix TDS620 oscilloscope. I would like to have the data in one line, however the program writes it into one row. I tried the transpose option of the "Write to spreadsheet file", but it does not affect the data, no matter if I wire it true or false... I cannot find any command to transpose a vertical array into a horizontal array....Smiley Sad
I would appreciate any advice.
regards,
istvan
(3,554 Views)
Strange Indeed what you are saying: in my configuration (LV 7.1) wiring nothing or a false constant to Transpose? input writes data in one line, wiring a true constant to that input writes to the file in a column. Smiley Surprised
Anyway, you posted this question in the wrong forum: this is the CVI board... you will find a larger group of LV experts inside the LabVIEW forum.
Message Edited by Roberto Bozzolo on 06-03-2007 12:28 AM
(3,544 Views)
