LabWindows/CVI
how we import Labview *.vi file into Labwindows/CVI
hello how i import or call *.Vi file into Labwindows/Cvi
which function should I use
Mundakarachi
(4,230 Views)
The easiest way to call a LabVIEW program in LabWindows/CVI would be to create a LabVIEW DLL. You will be able to share the LabVIEW code with CVI and other programming environments. The attached example program shows how to do this.
The following documents will show you how to create a DLL in LabVIEW and how to call it in CVI.
Creating and Calling LabVIEW DLLs with Various Data Types from CVI
Calling a LabVIEW DLL from a CVI/C/C++ Project
Thanks.
Wendy L
LabWindows/CVI Developer Newsletter
(4,212 Views)
