LabWindows/CVI
i AM TRYING TO CONNECT DATASOCKET SERVER THROUGH JNI USING LABWINDOWS/CVI. WHENEVER I RUN USING VIRTUAL MACHINE DS_OPEN FAILS AND RETURNS A NEGATIVE ERROE CODE.
If any one can help me out.
I am trying to connect datasocket server with java using labwindows/cvi. the problem is that when i execute the JNI stub the DS_OpenEx fails to execute and negative erroe code is generated.
I dont know why it is not working as i have included the library file . DLL is being generated fine and program gives no compilation erroe also.
Message 1 of 1
(3,087 Views)
