LabWindows/CVI
i hav encountered a problem "server refused the connection" while connecting FP-2010 with laptop
Hi Stephen S.
thanx
now my fp-2010 is working properly means there is no error and now status led also indicates no error.
but the another thing that i still not see the devices connected with it.(fp-rly-420)
i hav labview real time 7.1 on my target (fp-2010)
and labview 8.2 on my host(laptop)
can u help me in this regard what should i do
regards
mazhar
Message 11 of 21
(2,063 Views)
u shld chk ur system
Message 12 of 21
(2,057 Views)
thanx jawwad aur kuch bhi chk krna hai kia
Message 13 of 21
(2,055 Views)
hi Stephen S.
i am attaching new screen shots
plz check these and help me in this regard in second attachment the status is connected and running but still i cant see my device
thanx
Message 14 of 21
(2,053 Views)
hi Stephen S.
can u tell me about aik file
now i encountered a problem while saving iak file which is mentioned in this screen shot
regards
mazhar
Message 15 of 21
(2,029 Views)
Hi Mazhar,
From what I can tell, there seems to be something wrong with one of your devices, either the FP-2010 or the FP-RLY-420, or with the connection between them. First, double check all of your connections, inspect pins to see if anything is bent or unconnected, and ensure that you are powering your devices correctly by verifying that some LEDs are lit.
After that, do you have any other FP modules that you can connect with the FP-2010 to attempt to reprosuce the problem without that specific FP-RLY-420? Try to do the same things that are causing problems with a different module, as well as no module connected at all. Also, your last screenshot indicates that you have a FP-2000 controller as well, so try that controller with the FP-RLY-420 module to see if you get the same error.
If you can isolate the problem to one of the individual devices, the next step would be to arrange for a return of the device that is not working. To do this, you will need to call in at 1-866-ASK-MYNI (1-866-275-6964).
Stephen S.
Applications Engineering
Message 16 of 21
(2,003 Views)
Hi Stephen S.
now iam cheking FP-2010 without any module but i still  having the problem i cant access  the banks of FP-2010 .
can u tell me the softwares which are neccessary  for FP-2010 (should be on FP-2010).
thanx for ur interest
regards
mazhar
Message 17 of 21
(1,995 Views)
hi Stephen S.
i hav seen my fp-2010 in max but when i try to find devices the warning is prompted "unable to connect the data item on the module."
possible reasons 1.a connection is broken
2.the network module is not powered on
plz can u help me in this regard
regad
mazhar
Message 18 of 21
(1,988 Views)
hi Stephen S.
regad
mazhar
Message 19 of 21
(1,987 Views)
Hi Mazhar,
Since you have tested the system with only the FP-2010 on the system and are still getting the same problem, it seems like there is something wrong your controller and the way it is attempting to connect with other devices. If the software setup is able to see your FP-2010, it should also be able to see the other modules connected to your system. I would suggest that you call in to 1-866-ASK-MYNI (1-866-275-6964) to arrange for a return of the FP-2010.
Stephen S.
Message 20 of 21
(1,964 Views)
