LabWindows/CVI
in sprintf iam not getting correct value
char msg[256];
unsigned short int  tempp8=0xffff;
sprintf (msg, "Checksum: %u ",tempp8);
WriteLine (iFile, msg, -1);
while run the program the msg value get wrong data
msg=34085812
(4,637 Views)
Just tried your code and if works as expected on a Win7 machine with CVI2012SP1.
Which system are you running it on? Which CVI release are you using?
(4,629 Views)
SORRY SIR ..I GOT RESULT...
FIRST TIME AM CODING, I DINT PUT BREAK POINT IN THAT POINT.
THANK YOU
(4,617 Views)
