LabWindows/CVI
integrate a graphical interface in a dll
Hello
I developed an application that uses a graphical interface as input interface
the program executable mode works properly,
I created the project dll and I tried to use the language (MTL)
I managed to read the function and executed (by proving popup msg) but the problem I can not launch the GUI "graphical interface" , I think we should integrate. "uir" but I have not found means
you find attached the error msg when called, who can help me please
(4,293 Views)
this is the msg type
Error in call to LoadPanel
Parent PanelHandle: 0
UIR file name:"interface d'identification.uir"
Panel Resource ID: 1
Error Code: -94
File not found
juste for information
"interface d'identification.uir" it'ss my GUI that i need to load
(4,287 Views)
You are probably running into the probelem described into this KnowledgeBase entry.
(4,265 Views)
Hello
thankyou so much i resolve the probleme 🙂
(4,249 Views)
You're welcome!
(4,245 Views)
