LabWindows/CVI
service
I wish to modify a program to run as a service on Windows 7.  This stems from the need to run all the time, even if nobody is logged on to a machine.   How do I go about it ?
(3,899 Views)
Hey VetteGuy,
Can you tell me more about what you are trying to accomplish? So basically  you want your program to run nonstop after an initial start? Can't you just put it in a loop that will run forever?
What programming language are you using? LabVIEW, TestStand?
Please let me know.
(3,880 Views)
