LabWindows/CVI
interpolation between two series of data
Hello everybody,
i need to make an interpolation on a curve which have an interruption. It's a 1D array of data with a serie of NaN inside. I don't know hot to use the different type of interpolation in this case. I tried but i failed. Find here a picture of my problem.
Tanks a lot for you're help.
(3,908 Views)
Looks like a LabVIEW graph Smiley Wink In any case, I'd try to generate a new array without NANs which then can be used for all possible interpolation functions such as SPInterp, PolyInterp ...
(3,897 Views)
Accepted by Macarel31
You might get a more pertinent answer by posting in the LabVIEW forum.
Martin
Certified CVI Developer
(3,896 Views)
