is there any functions to match particular word from txt file.....
is there any functions in the string to check weather the particular word is there in the .txt file r not......otherwise which function will be suitable to check.....
(3,133 Views)
I suggest you use the FindPattern function. It finds a given pattern (which can be a word) in a string. Use the ReadLine function first to read the strings from the file.
(3,125 Views)
You can also use the functions in the regexpr.fp library in the CVI toolslib/toolbox directory for matching simple regular expressions.
(3,094 Views)
